Variable circuit based approach to adding jitter to PLL output.
IBO
Full Member level 3
Full Member level 3
hi all
Is there any variable circuit based approach to add jitter to PLL output.
thx
Re: jitter
do you mean that you want to add a certain jitter to the PLL output ?
Rania
Re: jitter
Dear IBO :
Do you want to design a spread spectrum clock ?
mpig
jitter
you can add noise to the input of VCO in your PLL by a noise source. noise source spec is depended in your need.
moghtada
    IBO
jitter
In my cadence develop environment there is a noise source model in library "ahdl",if you have such library you can simply use it for Spectre simulation.
Hope this will help!
    IBO
Re: jitter
hi
@rania regarding ur question rania; yes i do mean doing that. Its an SWS graduation for a programmable spread spectrum clock.
@ mpig09 yes, a programmable one
thx
[/b]
Re: jitter
Hi IBO,
What do you mean by SWS?
Rania
Re: jitter
@RANIA Si-Ware Systems (SWS) is a provider of analog/mixed-signal / RF design solutions and IP.
Re: jitter
Hi IBO,
I just wanna make sure It's our SWS
I'm an SWS graduate too, I was in the first graduation project sponsored by SWS
anyway to make spread spectrum clock generator you can make in in different ways but the most common one is to make Fractional N PLL as you will modulate the division factor N
best regards,
Rania
jitter
In power manager , Frequency jitter can make EMI lower . is this 'jitter' your say's?
best regards
Re: jitter
Where are you IBO? & how is your SSC PLL?
