joemmonster
Newbie level 3
Hi, im a newbie here and i am currently making a circuit for our school fair project. the only problem is i want to decrease the voltage of my battery from 9 volts to 5 volts without changing the current... then i searched through the internet and found out that the simplest way and efficient is to use an emitter follower voltage reducer/regulator like this:
http://hades.mech.northwestern.edu/...ransistors#Emitter_Follower_Voltage_Regulator
but i dont know what are the values needed for the resistor and zener diode, and type of transistor should i use.
if ever, i want the circuit to produce about 350 mA current, 5 volts...
thanks..
thanks..
