FreshmanNewbie
Advanced Member level 1
I have seen a couple of ethernet PHYs whose manufacturer datasheet recommends placing a ferrite bead on the power supply input of the PHY device who's value is, "Generally, a 100-220Ω (at 100 MHz) ferrite bead is used.". Mostly it is on the analog domain of the PHY.
You can find it in the first point under Power Section on page 1 of this Checklist : https://ww1.microchip.com/downloads/en/DeviceDoc/KSZ8041MLL-Hardware-Design-Checklist-00002856A.pdf
Can someone tell me why is such a value chosen at that particular frequency of 100MHz? Any specific reason with respect to the operating frequencies of Ethernet?
