nick703
Advanced Member level 1
Hello friends i have a UV led and and i want to create Led Driver for this UV Led. My UV LED is Edixeon S series UV LED
below is the data sheet **broken link removed**
Now i am using LM317 for LED driver with 12V Supply
Forward Volatge of LED = 3.2 to 5.0
Forward Current of LED = 350 to 700mA
And Resistor i have use 10ohm below is circuit diagram
Now problem is this UV led is very hot after turn on 1 min. and also this UV Led is dim after 20 to 25 day.
is that any solution to this problem how can i make led longer life and heat reduce?
