NiamhB90
Newbie level 2
![Newbie level 2](/styles/images/ranks/alevel2.gif)
I'm trying to set up my ADXL 346 with my Xilinx CoolRunner II CPLD. From my understanding of the datasheet I wrote some code in order to simply read the device ID. I am using SPI 4 wire transfer and my code is supposed to tell the ADXL346 to read from the Address 0x00 which should contain the device ID 11100110
The following is the VHDL code I downloaded to my CPLD board. Vdd through a resister divider network powers the device with 1.8 V through Vs and VI/O.
The CPLD outputs the values I want as in Sdi reads 110000000 and yet Sdo doesn't produce anything when tested on an oscilloscope.
please can somebody help me I am at my wits end trying to get this accelerometer to work!
Heres the VHDL code I used:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity DeviceID is
PORT( clk: IN STD_LOGIC;
reset,Int1,Int2,Sdo: IN STD_LOGIC;
--X0,X1,Y0,Y1,Z0,Z1 : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
Vdd,Sclk,CSn,Sdi : OUT STD_LOGIC);
end entity DeviceID;
architecture Behavioral of DeviceID is
-- first counter reduces the clock speed of the internal 8MHz clock to 125kHz
SIGNAL count_value : STD_LOGIC_VECTOR(7 DOWNTO 0);
-- second counter is for the case statements
SIGNAL count_value2 : STD_LOGIC_VECTOR(8 DOWNTO 0);
SIGNAL clk_int : STD_LOGIC;
---- 8MHZ clock divider
begin
count_proc : PROCESS(clk,reset)
BEGIN
IF (reset = '0') THEN
count_value <= "00000000";
ELSIF ( clk'EVENT AND clk = '1') THEN
count_value <= count_value+1;
END IF;
END PROCESS;
-- the clock for the case statements to follow should be now 125kHz
clk_int <= count_value(6);
count2_proc : PROCESS(clk_int,reset)
BEGIN
Vdd <= '1';
count_value2 <= "000000000";
ELSIF ( clk_int'EVENT AND clk_int = '1') THEN
-- the If statement means that once the initialisation of the Acc has been done
-- /Cs and Sclk stay high unless program is reset
IF (count_value2 = "000110011") THEN
count_value2 <= "000110011";
ELSE
count_value2 <= count_value2 +1;
END IF;
END IF;
case count_value2 is
-- Set up chip select and clock according to datasheet
when "000000000" => Csn <= '1'; Sdi <= '1'; Sclk <= '1';--0
when "000000001" => Csn <= '0'; Sdi <= '1'; Sclk <= '1';--1
when "000000010" => Csn <= '0'; Sdi <= '1'; Sclk <= '0';--2
-- R
when "000000011" => Csn <= '0'; Sdi <= '1'; Sclk <= '0';--3
when "000000100" => Csn <= '0'; Sdi <= '1'; Sclk <= '1';--4
when "000000101" => Csn <= '0'; Sdi <= '1'; Sclk <= '0';--5
-- MB
when "000000110" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--6
when "000000111" => Csn <= '0'; Sdi <= '0'; Sclk <= '1'; --7
when "000001000" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--8
-- A5
when "000001001" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--9
when "000001010" => Csn <= '0'; Sdi <= '0'; Sclk <= '1';--10
when "000001011" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--11
-- A4
when "000001100" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--12
when "000001101" => Csn <= '0'; Sdi <= '0'; Sclk <= '1';--13
when "000001110" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--14
-- A3
when "000001111" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--15
when "000010000" => Csn <= '0'; Sdi <= '0'; Sclk <= '1';--16
when "000010001" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--17
-- A2
when "000010010" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--18
when "000010011" => Csn <= '0'; Sdi <= '0'; Sclk <= '1';--19
when "000010100" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--20
-- A1
when "000010101" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--21
when "000010110" => Csn <= '0'; Sdi <= '0'; Sclk <= '1';--22
when "000010111" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--23
-- A0
when "000011000" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--24
when "000011001" => Csn <= '0'; Sdi <= '0'; Sclk <= '1';--25
when "000011010" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --26
-- D7
when "000011011" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --27
when "000011100" => Csn <= '0'; Sdi <= '0'; Sclk <= '1'; --28
when "000011101" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --29
-- D6
when "000011110" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --30
when "000011111" => Csn <= '0'; Sdi <= '0'; Sclk <= '1';--31
when "000100000" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --32
-- D5
when "000100001" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --33
when "000100010" => Csn <= '0'; Sdi <= '0'; Sclk <= '1'; --34
when "000100011" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--35
-- D4
when "000100100" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --36
when "000100101" => Csn <= '0'; Sdi <= '0'; Sclk <= '1'; --37
when "000100110" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --38
-- D3
when "000100111" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --39
when "000101000" => Csn <= '0'; Sdi <= '0'; Sclk <= '1'; --40
when "000101001" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --41
-- D2
when "000101010" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --42
when "000101011" => Csn <= '0'; Sdi <= '0'; Sclk <= '1'; --43
when "000101100" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --44
-- D1
when "000101101" => Csn <= '0'; Sdi <= '0'; Sclk <= '0';--45
when "000101110" => Csn <= '0'; Sdi <= '0'; Sclk <= '1'; --46
when "000101111" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --47
-- D0
when "000110000" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --48
when "000110001" => Csn <= '0'; Sdi <= '0'; Sclk <= '1'; --49
when "000110010" => Csn <= '0'; Sdi <= '0'; Sclk <= '0'; --50
when others => Csn <= '1'; Sdi <= '0'; Sclk <= '1';
end case;
end process;
end Behavioral;
library IEEE;
entity DeviceID is
begin
BEGIN
END IF;
END PROCESS;
BEGIN
Vdd <= '1';
ELSE
END IF;
END IF;
-- R
-- MB
-- A5
-- A4
-- A3
-- A2
-- A1
-- A0
-- D7
-- D6
-- D5
-- D4
-- D3
-- D2
-- D1
-- D0
end case;
end process;
end Behavioral;
