using Tvp5150 decoder with mcu
zalimturk
Newbie level 2
Newbie level 2
Hi friends;
I have to make a project.I must load the incoming datas in jpeg format from analog camera. I will use tvp5150 and will convert the datas from analog to digital and i will send these to st32 arm mcu,Is there any example about tvp5150 with mcu. I couldnt find anf of them
Hi
Basically the TVP5150 need simple register setting via I2C link
The hard work is to get the data from the TVP using the STM32 digital I/O
You will need to use interrupt and DMA for trnsfering data into RGB format
All the best
Bobi
The microcontroller specialist
