Using totem-pole output stage in RF design
nxing
Advanced Member level 1
China
totem pole output stage
Does anybody have the experience using totem-pole output stage in RF design? Is it specify for digital circuit?
Regards,
A totem-pole output is essentially the same as a push-pull output. The difference between it and a push-pull is the amount of current that it can sink or source. In digital TTL circuits totem-pole is a High-Low output, where push-pull will follow the input voltage.
I don’t see the reason to use totem-pole in RF amplifiers
