hosam_eldin
Banned
![Newbie level 3](/styles/images/ranks/alevel3.gif)
kst-tx01
Hello all,
I was doing a project using this RF modules from RAM, unfortunately it doesn't support UART, as sokrat said
Also, there are lots of noise, that's true, if you didn't send any data, you will get 0's and 1's randomly , it will pull the Rx output pin to low when signal is received from transmitter.
Now it seems that you need to deal with all this errors in your code which is not good.
unlike other modules available on the net which give you the ability to use UART directly.
If any one has success with that modules , please collaborate.
Thanks
Hello all,
Thanks
