mouzid
Full Member level 5
Hi all,
I'm using a simple divide by 2 Frequency divider circuit designed with an asyncronous reset flip-flop to get 50 Mhz from a reference clock of 100 Mhz. The resulting low speed clock s used to synchronise another circuits. I use the reset pin of the Frequency divider to enable and disable the synthesis of the low speed clock.
Is that technique a Clock gating technique ?
