ze_dib
Member level 5
Using pSpice demo 10.0, I would like to use the output of one simulation as a stimulus for another one.
I tried to export waveform by using the File/export/stimulus_file. As far as i can see, it worked.
Now I try to use this file on another simulation schematic. I set a source as VPWL_file and specified the stimulus file I exported previously.
Launching simulator, It generate an error message below :
What did I get wrong, or what didi I miss ?
Here is the stimulus file I use :
Added after 50 minutes:
Hi again,
I found what was wrong : In the stimulus file, three line are to be remove : lines 13, 14 & 15
When this is done, the simulation run fine.
Anybody know why we must remove those file, or if there is a way (or an option I miss) to remove them when exporting the file ?
Regards,
Ze_DIB
**** 12/08/05 15:22:09 ************** PSpice Lite (Jan 2003) *****************
** Profile: "SCHEMATIC1-simu_temp" [ Z:\work\Design_proto_FPGA\schma_simus\Gene_resolv\2k5\gene_resolv_num2-pspicefiles\schematic1\
**** CIRCUIT DESCRIPTION
** Creating circuit file "simu_temp.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
.STMLIB "../../../stimulus.stl"
* From [PSPICE NETLIST] section of C:\OrCAD\OrCAD_10.0_Demo\tools\PSpice\PSpice.ini file:
.lib "V:\phil_bjt.lib"
.lib "V:\infineon.lib"
.lib "V:\tex_inst.lib"
.lib "nom.lib"
*Analysis directives:
.TRAN 0 5m 3m 1000n
.PROBE V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source GENE_RESOLV_NUM2
Q_Q4 N00585 N01363 N01198 QBC857B/PLP
C_C1 N00527 N00443 1n
C_C2 0 N00487 1n
V_V2 N00772 0 15
V_V3 0 N00585 15
R_R1 N00432 N00443 33.2k
R_R2 N00443 N00487 33.2k
X_U1 N00487 N00504 N00772 N00585 N00527 LM324/5_1/TI
R_R3 N00504 N00527 3.48k
X_U2 0 N01148 N00772 N00585 N01363 LM324/5_1/TI
R_R4 N00527 N01148 33.2k
V_V4 N00432 0 PWL
+ FILE "..\..\..\stimulus.stl"
ERROR -- Invalid Time (.STIMULUS) in file "stimulus.stl" Line 13
R_R5 N01148 N01198 33.2k
Q_Q1 N00772 N00527 N00527 QBC847B/PLP
Q_Q2 N00772 N01363 N01198 QBC847B/PLP
R_R6 0 N00504 11k
Q_Q3 N00585 N00527 N00527 QBC857B/PLP
**** RESUMING simu_temp.cir ****
.END
Hi again,
* Z:\work\Design_proto_FPGA\schéma_simus\Gene_resolv\2k5\stimulus2.stl written on Thu Dec 08 16:27:58 2005
* by Stimulus Editor -- Serial Number: 1 -- Version 10.0.0
;!Stimulus Get
;! stimulus2_stim1 Analog
;!Ok
;!Plot Axis_Settings
;!Xrange 0.000000000000e+000 3.500000000000e-003
;!Yrange -2.547994947433e+000 2.994264125824e+000
;!AutoUniverse
;!XminRes 1.000000000000e-009
;!YminRes 1.000000000000e-009
;!Ok
.STIMULUS stimulus2_stim1 PWL
+ TIME_SCALE_FACTOR = 1
+ VALUE_SCALE_FACTOR = 1
+ (0.000000000000e+000, 1.582012744620e-003)
+ (1.000000000000e-010, 1.582012744620e-003)
Regards,
Ze_DIB
