Freddy_
Newbie
Hello everyone, I need help figuring this out. I am working on a project which involves SPI communication protocols.
The specifications of the project are.
1. I should have an SRAM initialized with data.
2. An SPI master (Transmitter), should be able to read some data from the SRAM, and send it to the Slave.
3. The Slave on the other hand will just send data back to master.
4. At the slave's receive end, I should have a pattern search block to look through the received data, if it matches what I want.
I have designed, the SRAM, the master, slave and the pattern search, but my problem is connecting all of them together, to perform the desired specifications.
I have instantiated all these modules in a top module as show. But I am not sure what to do to get data to move from the SRAM to the master, and to the slave. and finally, to be able to search through.
I am showing the code of my top module here.
I have tried designing an FSM to make everything work together at this point. But I am stuck on getting the SPI master to read data from the SRAM to the slave and later use the pattern search to detect the pattern.
Any idea of how I could do this would be very helpful.
module Top_Level( i_clk,
reset,
i_addr,
i_data,
Led_Show
// Input to the system
input i_clk;
input reset;
input i_data;
input i_addr;
output Led_Show;
// Data type declarations
wire i_clk;
wire reset;
wire i_data;
wire i_addr;
wire Led_Show;
//Intermediate connections
wire transmit;
wire mosi;
wire miso;
wire sclk;
wire chip_sel;
wire pattern_det;
// SPI state machine
parameter IDLE = 2'b00; // do nothing stage
parameter READ = 2'b01; // Read from the initialized memory block
parameter TRASMIT_FRAME = 2'b10; // Transmit the frame you read
parameter PATTERN_SEARCH = 2'b11; // At the receiving end of slave, search through to see if it matches our dsesire frame.
//Store the current state of the FSM.
reg [1:0] spi_state;
//Pattern to search for in recieved data
parameter pattern = 8'b00110101;
//Instantiate all the modules
//Slaves
SRAM_mem U1( .i_clk(i_clk), //Memeory
.i_addr(i_addr),
.i_data(i_data),
.o_data(transmit)
Master_TX U2( .i_Clk(i_clk), //Transmitter
.i_Rst_L(reset),
.i_TX_Byte(transmit),
.SCLK(sclk),
.MOSI(mosi),
.MISO(miso),
.SS(chip_sel)
Slave_RX U3( .i_Clk(i_clk), // Receiver
.i_Rst_L(reset),
.SCLK(sclk),
.MOSI(mosi),
.SS(chip_sel),
.MISO(miso),
.o_RX_Byte(pattern_det)
Pattern_Search U4( .clk(i_clk), // Pattern Search
.rst(reset),
.in(pattern_det),
.out(Led_Show)
// State Machine to control everything goes here
always@(posedge i_clk or negedge reset)
if(!reset) begin
spi_state <= IDLE;
end else
begin
case(spi_state)
IDLE: begin
if(!i_write)
spi_state <= READ;
else
spi_state <= IDLE;
end
READ: begin
if()
transmit <= o_data
endmodule
