using shift register for extend output is Safe ?
azadfalah
Full Member level 2
Full Member level 2
Hi friends
To increase the output of the microcontroller on a board, I have to use the shift register 74HC595
Assuming compliance with design tips
Is it still possible to activate the output of the register shift due to noise?
Is the use of microcontroller i/o directly is safer than using shift register ?
Is it safer to use transparent latch (74HC573) than shift registers (74HC595) ?
How can I be sure that the output will not turn on without my control?
thank
A shift-register, a latch and a microcontroller are different things.
What are you trying to do? What do you mean "increase the output"?
What do you mean "activate the output of the register shift due to noise"? Do you mean will noise trigger the shift register? Yes, it can.
How can a latch be "safer" than a shift register? That's like asking if an orange is safer than a banana.
I think you are trying to ask questions about noise susceptibility, but it's not clear. Maybe you should rephrase your questions.
* activated by noise: yes, on a bad design, almost No on a good design
* safer in which regard?
* by a good circuit. Useful RESET for example.
Klaus
I need extend outputs of STM32 MCU
-> The risk of accidentally ( Due to noise ) trigger the output should be very low
-> If the outputs have unwanted behavior , there is a risk of endangering someone's life
--> Of course, there are some protections, but I have to be sensitive in this area
In general, I have two options , use the latch to expand the output or use shift registers to expand the output
Using shift registers is better for me because they require fewer pins and routing
In which case is the system more sensitive to noise 74HC573 vs 74HC595 ?
* I could not find a better image for 74hc573 in my plan STR710 replaced by STM32 MCU
A good PCB layout is most important. In case you expect heavy noise: shield it (with a metal enclosure, shielded wires...) and use filters on the critical signals.
Consider methods to increase safety. Write the registers periodically. Let's say every 10ms. Then in case of a "wrong" bit it will be corrected automatically. Read about watchdog and redundacy checks
In case of inappropriate PCB layout, EMC filtering, to high external noise..
I don't think it's a problem of the used devices (ICs).
Signal quality is what matters.
And this starts with proper power supply decoupling capacitors ... I miss them on your schematics.
In case you already have them, then show them. Otherwise we will never know...
Klaus
Just to expand on what Klaus has said, if you're worrying about killing someone, there's A LOT MORE you need to be concerned with. What if your microprocessor software has a hidden bug and outputs the wrong data? All the EMC filtering in the world isn't going to fix that. You might need some external hardware just to prevent, for example, two signals being active at the same time. (I once destroyed an expensive amplifier in a radar because the transmitter and receiver were enabled at the same time. A simple logic gate would have prevented that from ever happening.) You also need software checks in place to prevent dangerous situations from happening. You can also use methods like triple-redundancy to mitigate noise problems.
As far as which of your latch or shift-register approaches is less susceptible to noise? They're identical. For a given process (CMOS, TTL) the susceptibility to noise is pretty much the same for all inputs. For example, for TTL less than 0.8 V is a logic zero; greater than 2V is a logic one. Anything in between those levels is indeterminate. If you have noise spike of greater than 2V on a clock line or a latch-control line, you've got a problem. Even if you have a spike of, say, 0.9V, you might have a problem.
Consider a cheap I2C expander such as the PCF8754T - they cost virtually nothing, easy to use as inputs OR outputs, expandable (3 address lines = 8 combinations * 8 bits = 64 I/O lines), give you interrupt on change capability and outputs are unlikely to get stuck at indeterminate states as long as I2C rules are followed. Only two connections needed to the MCU.
Brian.
Brian.
This doesn't solve the problem of killing someone because of an inadvertent bit-flip. A glitch on the clock or data line is still going to be a problem.
I think it is better to connect important I/Os directly to the MCU and extend less important I/Os with the shift registers
not necessarily ... noisy environment, bad layout, no filters ... may be more critical
Klaus
    azadfalah
The purpose of my question was the risks at worst case when we use I/O extenders
Yes, design tips definitely have a lot of impact and without design considerations there is no guarantee of performance
But using this type of output extender creates a risk that does not already exist
Thanks friends
What I tried to say:
It's not a (main) problem of port extender IC or microcontroller. If you don't have a good design your signals will get corrupted, it does not matter whether they come from/to the microcontroller or bus extenders. But I agree that "latched" devices may latch an erroneous state, and keep them.
Thus my recommendation to update the registers regurarily to automatically correct erroneous states.
Klaus
