using rtcc in pic18f66k22
shreyas_patel21
Full Member level 3
Full Member level 3
Hi all,
I am using pic18f66k22 and I want to display time on LCD using inbuilt RTCC module.
below is my code I tried but there is no update in seconds on LCD..
#include <stdio.h>
#include <p18f66k22.h>
#include "lcd.h"
#include "font.h"
#include "rtcc.h"
#include "functions.h"
/***************************configuration bits***************************/
#pragma config SOSCSEL = DIG
#pragma config XINST = OFF
#pragma config FOSC = INTIO2, FCMEN = OFF,IESO = OFF,PLLCFG = ON
#pragma config PWRTEN = ON, WDTEN = OFF,BOREN = OFF
#pragma config MCLRE = ON
#pragma config CP0=OFF, CP1=OFF,CP2=OFF, CP3=OFF, CPB=OFF, CPD=OFF
#pragma config WRTC=OFF, WRTB=OFF,WRTD=OFF
#pragma config EBRT0=OFF , EBRT1=OFF , EBRT2=OFF , EBRT3=OFF , EBRTB=OFF
#pragma config STVREN = ON
//---Function Prototypes---
void RTCC_configure(void);
//---Global structures used in deep sleep library---
rtccTimeDate RtccTimeDate ,RtccAlrmTimeDate, Rtcc_read_TimeDate ;
unsigned int background=0xf800, font=0xffff, red=0xf800;
unsigned int violet=0x3191, blue=0x0457, yellow=0xf661, green=0x4EC4, black=0x18c3;
//***********main function***********
void main (void)
	unsigned char x = 1, y = 2;
	unsigned char test[2] = {0,0};
	unsigned int second = 0;
	OSCCONbits.IRCF0 = 1;	//HFINTOSC 16MHz with PLLEN
	OSCCONbits.IRCF1 = 1;
	OSCCONbits.IRCF2 = 1;
	OSCTUNEbits.PLLEN = 1;
	ANCON0 = 0x00;
	ANCON1 = 0x00;
	ANCON2 = 0x00;
	ADCON0 = 0X00;
    ADCON1 = 0X00;
    ADCON2 = 0X00;
	TRISA = 0x00;
	TRISB = 0X00;	//output
    TRISC = 0X00;	//output
    TRISD = 0X00;	//output
    TRISE = 0X00;	//output
	TRISF =  0Xff;	//input
	PORTCbits.RC0 = 0;//lcd reset
	delay_ms(5);
	PORTCbits.RC0 = 1;
	PORTCbits.RC0 = 1;
	PORTAbits.RA5 = 1;
	LCD_init();
	font_init();
	setfont((void *)font_Calibri_10);
	LCD_paint_block(x+0, y+0, x+159, y+127, font);
	RTCC_configure();
	while(1)
		RtccReadTimeDate(&RtccTimeDate);
		second = RtccTimeDate.f.sec;
		test[0] = second | 0x30;
		test[1] = second | 0x30;
		LCD_OutText(40,67,test,black);
unsigned int i=0,j=0;
   RtccInitClock();                                       //turn on clock source
   RtccWrOn();                                            //write enable the rtcc registers
   mRtccSetClockOe(1);                                    //enable RTCC output on RTCC output pin
  // PIE3bits.RTCCIE=1;
   //Set Date and time using global structures defined in libraries
   RtccTimeDate.f.hour = 1;                                //Set Hour
   RtccTimeDate.f.min =  0;                                //Set minute
   RtccTimeDate.f.sec =  2;                                //Set second
   RtccTimeDate.f.mday = 4;                            //Set day
   RtccTimeDate.f.mon =  4;                            //Se month
   RtccTimeDate.f.year = 09;                             //set year
   RtccTimeDate.f.wday = 6;                              //Set which day of the week for the corrsponding date
   RtccWriteTimeDate(&RtccTimeDate,1);                    //write into registers
   mRtccOn();                                            //enable the rtcc
void delay_ms(unsigned int ms)
	unsigned int x;
	for(x = 0; x < 8*ms; x++)
			TMR1L = 0x00;
			TMR1H = 0x00;
			T1CON = 0x31;			//turn on timer1 1:8 PRESCALE
			while(TMR1L < 0xFA);	//125uS
			T1CON = 0x30;
void delay(unsigned int i)
	for(;i>1;i--);
any suggestion would be helpful..
thank you!
Regards,
shreyas.
Hello again..
I have found the problem in upper code, I configured the rtcc clock properly and it done,
but now I have problem that how to enter into sleep mode?
and the RTCC is in-built so if we turn off the pic it will reset the RTC..
Don't do C but the 66K22 looks an interesting chip with is RTCC.
You should just be able to put the chip to 'Sleep' when you have power applied - this tutorial shows you how.
www.gooligum.com.au/tutorials/baseline/PIC_Base_C_3.pdf
Seems there are no separate power lines for the RTC so if your main power is off you will have to use a battery backup to allow the RTC to function in Sleep mode.
That chip is optimised for very low power while in Sleep mode so a small battery, even a button cell should last a long time.
In case of total power loss in a real time situation you could always write the RTC registers to EEPROM every minute or 5 minutes and restore them at Power on / program Start, then you only loose the time that the power was lost.
Thank you wp100!
my problem is that i have used 3.3v supply for LCd and pic also from the same source,
If I connect battery than my LCD will also be turn ON?
where should I connect the small battery to operate only RTC module?
Two simple methods show below.
The first way means the pic is running at 3.1v to the 3.3v lcd , but that should work .
The second way ensures all voltage levels are the same - all 4 diodes must be the same standard or schottky types.
