vkj
Newbie level 6
Rotary switches are extremely convenient to use for input attenuator switching. AN old Elektor ac-voltmeter design uses a rotary sw. mounted on the pcb itself and the input resistors and caps mounted around the pins (on the board). SImilarly old timers will remember old TV and radios used rotary switches for channel switches (point to point wiring).
I am tempted to use a rot. sw for range switcihing for a DIY DSO freq upto 20MHz (hopefully). Most designs use reed relays and/or separate amps for each range. Would a rotary switch work or would it be not worth the trouble? Any tips on using them at these frequencies?
Thanks
vkj
Thanks
vkj
