Using rotary switch with a PIC16F877
abdullahbicen
Newbie level 2
Newbie level 2
I want to use 1 pole-12 ways rotary switch with a pic16f877 in my project. My problem is switch has a lot of pins and I don't want to use pic's pins in order to read switch's position. Is there another way of doing this?
Re: rotary switch
Use two numbers of 74HC148 in cascade.
Regards,
Re: rotary switch
Or use a rotary encoder (requires 2 pins for the A and B encoder outputs)...
Mike
rotary switch
you could also use the ADC port
Connect the ADC port to a potentiometer, (center to adc port, max end to +5V and min end to GND)
Since you need 12 positions, each position change occur at intervals of 30 degrees.
or 1023/12= 85 bits (approx)
To get the position number, divide the ADC value (10 bit data) by 85, the result obtained (without approximation) will be the position selected.
arb
rotary switch
If you want to use Switch use 12 resitors and the ADC port
Re: Thank you all
Thanks for your help. I am planning to use two 74ls148. Since I am new to pcb design, I am not sure to use digital and analog parts on the same pcb.
rotary switch
you can use both
