john1998
Newbie level 6
I am using a Raspberry Pi 3 Model B to read the signal generated by a function generator. I have used PCF8591 fitted in YL-40 PCB as the ADC. I have used python for establishing the I2C communication between the Rpi and PCF8591. But, I am getting undesirable values when I run the setup.
The connection between the Rpi and PCF8591 are as follows-
(Rpi) (PCF8591)
Pin 1 -> VCC
Pin 3 -> SDA
Pin 5 -> SCL
Pin6 -> GND
The generated wave was: Frequency = 1KHz; Amplitude = 1 Vpp; DC offset = 0
A picture of the python code I used, the output when the function generator is not connected, the output when the function generator is attached and the connection between the ADC and the function generator is attached below.
(Rpi) (PCF8591)
Pin 1 -> VCC
Pin 3 -> SDA
Pin 5 -> SCL
Pin6 -> GND
