arnab913
Junior Member level 3
- Joined
- Jul 27, 2012
- Messages
- 30
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Chittagong, Bangladesh
- Activity points
- 1,515
Hello,
I am working with the 16f877A,using PWM with ADC. I've writtten a code,but it is not working.....I am cheaking it again & again..but nothing. :-(
The motor works without the ADC value...wheather it is 5 or 0V.
I don't understand why???
Here is the code....
Oscilloscope is not also showing PWM! Pls help.....
Here the image
double pwm;
void main() {
PWM1_Init(1000); // PWM of 1kHz
ADCON1=101000010;
TRISA=0b00000001;
PORTA=0;
TRISB=0b00000010; // portb as output
PORTB=0;
PWM1_Start(); // starting PWM
if (PORTB.f1==1)
while(1)
pwm=ADC_Read(0);
PWM1_Set_Duty(pwm);
delay_ms(100);
Here the image
