raju_kambar
Full Member level 3
Using "PSPICE" software, Can we generate equivalent CKT and Obtain desired Parameter
I downloaded and installed the Student Version Electronics Lab "PSPICE" software.
I have the following doubts regarding on the "PSPICE" software
(1) From " PSPICE" software, can we import our normal electronic circuit and convert it into equivalent circuit for small signal analysis.
(2) If we import our small signal model equivalent circuit to the PSPICE software. Is it possible to obtain the small signal model equivalent circuit desired parameters such as Input and Output Impedance, Gain, Source Impedance, Noise Figure, and Linearity. If so, what option I need to use to obtain desired parameters.
(3) I have tried to import my normal .jpg equivalent circuit to the student version PSPICE software, it is showing error as file format should be ".ini" format. If it so, how to convert our normal schematic into ".ini" format.
Can you clear my doubts.
