no there is no problem in that.... the only thing is you gotta know which line to strobe with a high or low signal using the PC to make it input the signal given by us....
The original PC parallel port wasn't bidirectional, so the only input bits were the five status pins. Later machines have enhanced modes that can input from the eight data pins.
Remember that most modern operating systems won't allow a user-mode program to directly access I/O ports. You may need a special port access driver.
Lots of info at "Parallel Port Central": **broken link removed**
