Using oscilator as a clock
icd
Junior Member level 3
I am trying to use a fast and slow clock oscillators as a two clocks to two 8-bit counters. The problem the 2 counters are not counting. They give me X as an output. I will appreciate any help to figure out the problem. below is my code and an image of the output:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all ;
use ieee.std_logic_unsigned.all ;
LIBRARY work;
ENTITY ring IS
	PORT
		en_slow :  IN  STD_LOGIC;
		en_fast :  IN  STD_LOGIC;
		slow_clk :  OUT  STD_LOGIC;
		fast_clk :  OUT  STD_LOGIC;
		counter1, counter2 : out std_logic_vector(7 downto 0)
END ring;
ARCHITECTURE beh OF ring IS
SIGNAL	SYNTHESIZED_WIRE_0 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_1 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_2 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_3 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_4 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_5 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_6 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_7 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_8 :  STD_LOGIC;
SIGNAL	SYNTHESIZED_WIRE_9 :  STD_LOGIC;
signal cnt1, cnt2 : std_logic_vector(7 downto 0):=(others=>'0');
BEGIN
slow_clk <= SYNTHESIZED_WIRE_7;
fast_clk <= SYNTHESIZED_WIRE_2;
SYNTHESIZED_WIRE_1 <= NOT(SYNTHESIZED_WIRE_0);
SYNTHESIZED_WIRE_3 <= NOT(SYNTHESIZED_WIRE_1);
SYNTHESIZED_WIRE_8 <= en_fast AND SYNTHESIZED_WIRE_2;
SYNTHESIZED_WIRE_4 <= NOT(SYNTHESIZED_WIRE_3);
SYNTHESIZED_WIRE_5 <= NOT(SYNTHESIZED_WIRE_4);
SYNTHESIZED_WIRE_7 <= NOT(SYNTHESIZED_WIRE_5);
SYNTHESIZED_WIRE_9 <= NOT(SYNTHESIZED_WIRE_6);
SYNTHESIZED_WIRE_0 <= en_slow AND SYNTHESIZED_WIRE_7;
SYNTHESIZED_WIRE_6 <= NOT(SYNTHESIZED_WIRE_8);
SYNTHESIZED_WIRE_2 <= NOT(SYNTHESIZED_WIRE_9);
slow_clk_counter1_process : process(SYNTHESIZED_WIRE_7)
                  begin
                  if(SYNTHESIZED_WIRE_7'event and SYNTHESIZED_WIRE_7='1')then
                  cnt1<=cnt1+1;
                  end if;
                  counter1<=cnt1;
                  end process;
fast_clk_counter2_process : process(SYNTHESIZED_WIRE_2)
                  begin
                  if(SYNTHESIZED_WIRE_2'event and SYNTHESIZED_WIRE_2='1')then
                  cnt2<=cnt2+1;
                  end if;
                  counter2<=cnt2;
                  end process;
END beh;
The code you posted doesn't even produce the waveforms shown.
oops my mistake I didn't set en_fast to low to start, still Modelsim hits a iteration limit as the "ring" keeps cycling in delta time and won't let the simulator reach a stable state. This code is probably not synthesizable. Why would you want to do this, what is the point?
adding delays to all the assignments....
SYNTHESIZED_WIRE_1 <= NOT(SYNTHESIZED_WIRE_0) after 10 ns;
results in the counters counting correctly.
Thank u for ur help. I am using Quartus 9.1, so I show the WF without using modelsim and I did add delay but still not working. Is this what u meant by adding delay
library IEEE;
LIBRARY work;
ENTITY ring IS
	PORT
	(rst : in std_logic;
END ring;
BEGIN
slow_clk <= SYNTHESIZED_WIRE_7 ;
fast_clk <= SYNTHESIZED_WIRE_2 ;
SYNTHESIZED_WIRE_3 <= NOT(SYNTHESIZED_WIRE_1) after 10 ns;
SYNTHESIZED_WIRE_8 <= en_fast AND SYNTHESIZED_WIRE_2 after 10 ns;
SYNTHESIZED_WIRE_4 <= NOT(SYNTHESIZED_WIRE_3) after 10 ns;
SYNTHESIZED_WIRE_5 <= NOT(SYNTHESIZED_WIRE_4) after 10 ns;
SYNTHESIZED_WIRE_7 <= NOT(SYNTHESIZED_WIRE_5) after 10 ns;
SYNTHESIZED_WIRE_9 <= NOT(SYNTHESIZED_WIRE_6) after 10 ns;
SYNTHESIZED_WIRE_0 <= en_slow AND SYNTHESIZED_WIRE_7 after 10 ns;
SYNTHESIZED_WIRE_6 <= NOT(SYNTHESIZED_WIRE_8) after 10 ns;
SYNTHESIZED_WIRE_2 <= NOT(SYNTHESIZED_WIRE_9) after 10 ns;
                  begin
                  if(rst='1')then
                  cnt1<=(others=>'0');
                  elsif(SYNTHESIZED_WIRE_7'event and SYNTHESIZED_WIRE_7='1')then
                  cnt1<=cnt1+1;
                  end if;
                  counter1<=cnt1;
                  end process;
                  begin
                  if(rst='1')then
                  cnt2<=(others=>'0');
                  elsif(SYNTHESIZED_WIRE_2'event and SYNTHESIZED_WIRE_2='1')then
                  cnt2<=cnt2+1;
                  end if;
                  counter2<=cnt2;
                  end process;
END beh;
when I used xilinx here is what I got
Is there any synthesizable code for ring oscillator I can get one slow clock and another one fast. That will help a lot.
