winglj
Full Member level 4
active biasing
Hi, everyone. I have a question about what kind of op-amp I should use to design an active biasing for a power transistor.
Basically the I am going to employ a sensing resistor to capture the power supply current from Vcc to transistor. The voltage drop is then compared with a reference voltage by an op-amp. And the op-amp output is connected to the transistor base to provide negative feed-back.
I am wondering which op-amp I should use? Can the basic general purpose op-amp usable, since the bias circuit only require operating at DC. If so, which op-amp (band and part number) do you recommend?
