Using op amp LM741 for guitar overdrive
headman333
Member level 5
Member level 5
Is there anybody has a tested circuit using op amp LM741 for guitar overdrive?:D
lm741 guitar distortion circuit
Overdrive is just extreme clipping distortion.
You can let the opamp clip its output when its input level is too high.
You can add back-to-back diodes in the negative feedback of the opamp.
You can have the opamp drive two back-to-back diodes that are connected to ground.
overdrive op amp
The circuitry that Audioguru describes is the most basic type of overdrive type distortion and could be described as fuzz.
A lot will depend on the exact type of overdrive that you want . If it is the type of overdrive that you get with a amp bring driven to its maximum and then distorting well this can be quite dificult.
It can only be done by actually using a amp and speakers being overdriven and ecoustically ballanced and then re miced up.
All sorts of things come into play, phase shift, attenuation, speaker distortion sustain, etc.
guitar simple circuit overdrive
Thanks a lot for the idea that both of you had shared to me. Do you have any circuit that can i copy?
guitar overdrive diodes
Look at Guitar Overdrive Circuit in Google. There are 81,000 articles. Most circuits are the same.
Here is the first link: **broken link removed**
setting guitar overdrive
Thanks AUdioguru!
