fastcomponents
Newbie level 5
we're currently designing a servo controller for these motors that we've started getting made up **broken link removed**. The idea is to make a 'servo beater' for robotics applications, retailing at $15 - $20. Basic specs to include a variety of gearboxes (and nominal RPM outputs 40 ~ 250RPM), quadranture encoding, RSXXX, I2C, SPI, PWM, analogue, arbitrary (absolute & relative) positioning commands, arbitrary torque output commands, temperature overload control / feedback... etc.
To keep the cost down, I wondered if we could use the body diodes of the MOSFETs instead of using schottky diodes. Currently in our prototype we're using 2 P-channel (topside) FDFS2P103 (fairchild), and 2 N-channel (lowside) FDFS6N303 (fairchild). But in a S08 package they take a lot of space on the miniature board. Therefore ideally we could use some S023 MOSFETS, and use the body diode.
Quick specs - motor stall current is about 1.5A. Supply voltage is 4-6v, pwm switching is variable between 2 and 8khz to minimise audio noise approaching discontinuous operation, and switching loss at higher power levels.
I wonder if the body diode would be fast enough at these switching speeds?
Any ideas for alternative MOSFETS? Unit will be fitted with miniature heatsink to aid dissipation, and the aim is to mount the board on top of the motor casing (yes it is small!!!)
Thanks, Tom.
Fast Components - the best way to buy components!
Thanks, Tom.
