using lamp as resistor
thebadtall
Full Member level 6
Full Member level 6
Hellas
Hello, I measured a typical lamp and is 100Ohm / 40W
Can I use it as replacement of a high wattage resistor of same value ?
Thank you
The resistance when an incandescent bulb is cold is about 1/10 of the resistance when the lamp is on and the filament heated.
A 100 ohm resistance would results in (220²)/100= 484W
for 40v @220v the operating resistance is R= 220² / 40 = 1210 ohm
Such a device can be used - for example - as a non-linear gain controlling element (with positive temperature coeff..) in harmonic oscillators. In fact, it was used by Mr. W.R. Hewlett in 1939 to stabilize the world's first WIEN oscillator.
P=V*I and I=V/R so you can write P= V * (V/R) = V²/R
If you solve for R then R= V²/P
V=220v
P=40W
R = 220²/40 = 48400/40 = 1210 ohm
Alex
