Using jstag program for arm7 developing
keen
Full Member level 2
Full Member level 2
hi to all,
first of all you need nice tool for arm7 developing.
- compiler: ads, sdt, greenhills, iar etc
- jtg interface to pc: wiggler(1$) other some k$.
Thats all, only greenhills suports wiggler & macraigor.
Approach: must do somehing by yourself:
- write sw which burn you appl. in flash
- semihosting approach (!=wiggler) or
- via jtag download sw in ram which will via rs232
download appl. sw & burn it in flash & that appr.
cost almoust nothing ..
wiggler=lpt+hc245+flat cable (lpt <==> jtag interface)
direct to the jtag pins of arm7.
Flow chart:
- run wigger & wigg. support sw & set arm7 mode to [0.0]
- via jtag download script file to config. arm7 memory&regs
- compile support sw for those ram (supp. serial burning)
- run sw in ram, must get response on rs232
- send appl. sw to rs232(S3 motorola format) sw in ram will
burn incoming appl. sw in flash
- change arm7 mode to [1.0] & after reset sw from flash will
wakeup ..
regards Keen
arm7tdmi ram iar
Hi
Is there an JTAG sch that I can use it for @ds 1.2 ?
What developement tools are enough for starting AR*M7 with AT9*1
or su*msong arm*7?
bye
iar arm7 jtag lpt
As keen wrote you need compiler( for example greenhills) and wigller interface.
Schematic of Wiggler is available from
http://jtag-arm9.sourceforge.net/hardware.html
it is all.
Only greenhills supports the Wiggler. With ADS you must use expensive ICE.
Best regards
Vlad
arm7
Hello,
GreenHills 3.6 is here on my disc, but I have not full license file
for it anybody can supplay this ful license file ?
ragards Keen
p.s.
Vladz your GreenHill arm 2.0.1 tool with the crack works but
the utility for ICE debugger doesn't. Only arm micro browsing
is available, debuging on chip via wiggler does not work, tested.
IAR ARM tool also support wiggler.
hi, keen
I see 3 different PC stations with installed Multi2000 v2.0.1, that works with support of debuging via wiggler without problems. I tested it only under Wi98, I don't now if it works under win2000/XP.
Could you PM me abut your poblems with Multi2000 ?
Vlad
