Using interrupts in C language
SUNBELT
Member level 2
Member level 2
I am trying to use interrupts in c programing, I am a beginner in this subject,
Please provide me with some basic information about this subject.
INTERRUPTS IN C
every compiler has his enique interrupt routines..
some compiler has pragma ... like IAR
tell me the compiler that you are working...
Re: INTERRUPTS IN C
I am using visual c++6 as compiler, I write c codes in win32 console application enviroment
INTERRUPTS IN C
can you explain more clear..
VC++ means PC programming and you want to have interrupt to the PC?
INTERRUPTS IN C
You may be innocently wading into very deep water. Interrupts usually involve writing a device driver. That's a very complex project in modern Windows. Win32 won't get you there.
If you explain what you are trying to build, maybe someone will know a shortcut solution.
Re: INTERRUPTS IN C
I want to use parallel and serial port interrupts.
INTERRUPTS IN C
You can try a MCU software design project.For example,a simple protocol with C in 8051.I also think PC is too big for you:)
INTERRUPTS IN C
interrupts in C in like in assembly
you just set the interrupt vector like
example
here the code for i*a*r* compiler
for avr mcu interrupt for timer 0
#pragma vector=TIMER0_OVF0_vect
__interrupt void timer0interrupt (void){
