Using #INT_RB in 16F877
oguzmania
Newbie level 2
Turkey-Konya
#int_rb
Hi from Turkiye.
Firstly i am sorry for my bad English.
If I explain my project; (I use CCS C)
I have 4 equivalent sound detector circuit and then i will use op-amp in the exit of this 4 circuits.If detector detects sound op-amp (comparator) shows +5V , if not it shows 0 V.
This detector circuit's microphones are in different points.So if i send a sound signal ,the signal arrives this detectors in different times.
So I want to find this different times.(Or time differences)
Firstly i am using 16F877 and exit of comparator line combined RB<4:7>
For example;
1.detector:RB4
2.detector:RB5
3.detector:RB6
4.detector:RB7
I want to find time differences with using INT_RB and Timer1.
I set Timer 1 with using my conditions.(Example; using sound velocity etc...)
I don't want to using Timer 1 with it's interrupt.
For example this time differences;
1.detector:0 second
2.detector:120us
3.detector:2000us (2ms)
4.detector:25000us (25ms)
In my calculation i must measure 30us to 30 msn (Timer 1 64536-65536)
But i didn't make it in CCS.
I want;
if detector1 is logical1;
if (input(pin_b4))
timer 1 starts
and time1=0
if (input(pin_b5))
time2=get_timer1()
if (input(pin_b6))
time3=get_timer1()
if (input(pin_b7))
time4=get_timer1()
I want to find with time differences not using interrupt timer 1.
And when RB<4:7>pins 5V-->0V i don't want a new interrupt.
I am waiting your answers.I hope i explained my problem...
Peace be with you...
Oguz
int_rb ccs
Your scheme will work if you take care of the following :
1. You should configure the RB4 to RB7 bits as input with pull up.
2. You should ensure that each bit will only change state once during a measurement cycle. This can be achieved by using four external Set/Reset Flip-Flops which could all be reset using a bit output from PIC and get set when the audio comparator outputs connected to their set inputs go low for the first time. Further changes of the comparator output will be removed by the SR FFs unless again reset by PIC.
I hope you can take care of other language specific issuues.
Regards,
Laktronics
Added after 3 hours 13 minutes:
You should also read portB once to start with and once after every interrupt.
Regards,
Laktronics
    oguzmania
int_rb
/*************************entegreterbiyecisi@yahoo.com******************************/
int ca,ne,can,nec,change;
/***entegreterbiyecisi@yahoo.com***/
#int_rb
sensor(){
if (bit_test(port_b,7)) {ca=1;}
if (bit_test(port_b,6)) {ne=1;}
change=1;}
void main() {
enable_interrupts(int_rb);
while(true){
if(!input(dwn)){ //start
dsp_data=0;
change=false;
data_bitti=false;
output_high(role_1);
while(!data_bitti){
while(!change){
dsp_yaz(10);
if(!input(up)){ //stop
goto stop;}}
if(dsp_data<9999){
dsp_data++;
dsp_ayir(dsp_data);
change=false;
if(dsp_data>=role1_data){
output_low(role_1);}
if(dsp_data>role1_data){
data_bitti=true;
change=true;
#fuses xt,noPROTECT,nowrt,noPUT,BROWNOUT,nolvp,WDT
//watchdog timer fuse a
WDT
void main()
set_rtcc(0);
setup_counters(RTCC_INTERNAL,WDT_2304MS);
//olarak yazılırsa 2304ms den önce
restart_wdt();
//program içinde değişik yerlere yazılmalıdır
//aksi takdirde WDT pic i reset eder
/**********www.picproje.org TURKiYE de*****************/
