hm_fa_da
Full Member level 5
Is using of GSM module dangerous in hazardous area ? i.e gas station.
I'm trying to design an Electromechanical turbine gas flow meter which should have GSM module for remote reading.
whole the circuit is encapsulated in an Aluminium box and powered by battery. because of aluminium box, the GSM antenna should be placed outside the box.
or maybe i use an IP plastic box and place the antenna inside the box ?!
My question is for GSM antenna radiation energy, is it dangerous ?!
I've seen some equipment placed at same location (same ambient parameters) and have GSM Module too.
Should i consider anything special for the module ? i.e limiting maximum transmitter power or anything else ... ?
Thanks & Best Regards.
