ashwinvl
Junior Member level 2
Hi, I am using Encounter RTL Compiler to insert scan chains (muxed-scan) in my design..
I do not have a dedicated shift enable port and hence I am using a functional data pin as my shift-enable signal in the test mode..
But I come to know that I need to insert a test point manually, at this functional pin fanout inorder to gate the shift enable logic path (i.e prevent logic values at this port to travel thro' shift enable path in functional mode). I understand the purpose but am unable to zero-in on a test-point instance,i.e what logic should be inserted??... Will a 2-i/p AND gate on the shift-enable logic path with one input connected to a test control signal be sufficient??
Someone kindly help.. Thank u
