Using FPGA control image sample timing
amekle
Newbie level 2
Newbie level 2
Hi all friends:
I want to use FPGA to control image sample (The image:720×288).Is a good solution using VHDL to program a big counter? have pels signals(13.5Mhz)and row signal.Thnk u!
can you describe your problem more may be we can find a solution
I don't understand your question:
"Is a good solution using VHDL to program a big counter?"
I think you can search in **broken link removed**
there is a example about image processing by VHDL and FPGA. A lot of information
theoretically you can write a VHDL counter for anysize but you have to meet some timing requirements , however 13.5 MHz can be met in modern FPGA with a very large counters "64 bit for example can run at this speed". I am not sure but I have made a pipelined multiplier "48X48 bit that can run more than 80 MHz I assume (really I don't remember the speed but it was but I guess it was 85 MHz)", on Virtex FPGA so I guess the 13.5 MHz can be met with a counter as large as 64 bits which is more than suitable to any application.
Thanks! I use video decoder chip SAA7111AHZ.Video format:pAL standards .50Hz field frequency.720 active samples(pels) per line.It can give some signals:pels signal(13.5Mhz).I want to use FPGA to control sampled data which should be written to SRAM. So FPGA should generate sram address during SAA7111AHZ conversion.I need a good solution.
