dream_taker
Junior Member level 1
If we use fingering in layout the Drain/source cap is reduced by that factor. Is it the same case when we use Hspice. Imagine I set M=2 in hspice which means I am using a finger of two, will hspice consider half the cap at Drain/Source?
We also give diffusion area and diffuison periphery values in schematic for a transistor. So which will Hspice takes into account ?
