alfie.max15
Member level 2
I am using Atmega 8 16 bit counter.
It works fine with the internal clock.
But when tryin to use a signal as external clock on T1 pin on the uC the pin stays high all the time.
I used the above code so as to use the external clock on pin T1
Code C - [expand] 1 2 3 4 5 6 7 DDRD &= ~(1 << DDD5); // Clear the PD5 pin // PD5 is now an input PORTD |= (1 << PORTD5); // turn On the Pull-up // PD5 is now an input with pull-up enabled TCCR1B |= (1 << CS12) | (1 << CS11) | (1 << CS10); // Turn on the counter, Clock on Rise
