matrixofdynamism
Advanced Member level 2
- Joined
- Apr 17, 2011
- Messages
- 593
- Helped
- 24
- Reputation
- 48
- Reaction score
- 23
- Trophy points
- 1,298
- Activity points
- 7,681
Ethernet is ubiquitous and is also built into many microcontrollers, especially the PIC which this question is about.
I need reference to a resource that will demonstrate what type of applications one can create by using the Ethernet protocol. Ethernet basically provides a means for devices to talk with each other over longer distance and the higher layers used with Ethernet do most of the work for a given application. Is there an archive of projects done using PIC Ethernet or book that you anybody may recommend? I want to see how people use the power of Ethernet in practical applications.
