Using design compiler for synthesis
wisemonkey
Junior Member level 3
San Jose
I will be using design compiler to synthesize design. My design contains `ifdef-`endif blocks. I can compile and simulate it using synopsys vcs as:
vcs +define+<one of possible value for `ifdef> filename.v
That would compile and simulate but I can't seem to find how to synthesize it the same way?
Thanks for inputs
Hi, you can use a .v file include the `define and add this file to sythesis it
Thanks bffgot,
but can u please elaborate a little bit? I've never used include before so I may not get idea easily
Thanks
Hi wisemonkey,
u can add `define "one of possible value for `ifdef" in a define.v file, then add this file to sythesis it
Thanks bffgot,
Thanks
You can create one file consists all parameters and then include that file inside the RTL file. For example you have parameter GATED_CLK and WIDTH_CH , define in one file named test_def.v as follow:
`define GATED_CLK
`define WIDTH_CH
you have to include above file inside your RTL file , for example your RTL file is test.v. Add following line inside the test.v:
`include "test_def.v"
module test (in, out);
endmodule
This will work in DC.
Thank you very much dianin and bffgot.
This way it sounds really easy :)
Thanks again I'll report in if I happen to hit a block again
DC supports ifdef in the RTL files.
you can add your defines just like how you do it in vcs
add +define+<VALUE> to the read_verilog command
Thanks chipmonkey,
Thats wat I was looking for :) Now I can test design with add and finally use include file
Btw I assume it would be
 read_verilog {design files} add +define+<value>
Or is it
read_verilog {design files add +define+<value>}
In any case I'll try both. Thanks
There is no "add".
command will look like the following:
read_verilog {design files} +define+<value>
replace <value> with what you need to define
my bad, Thanks for correcting :).
I assumed add is a part of command and yes I know about replacing value
In the man page, it is said as below:
NAME
read_file
Reads designs or libraries into memory, or reads libraries into
the shell.
SYNTAX
list read_file
file_list
[-define macro_names]
[-format format_name]
[-ilm]
[-library library_name]
[-rtl]
[-single_file single_file_name]
[-work library_name]
[-scenarios scenario_list]
[-active_scenarios active_scenario_list]
[-names_file file_list]
Data Types
file_list list
macro_names list
format_name string
library_name string
single_file_name string
scenario_list list
active_scenario_list list
SYNTAX for lc_shell
list read_file
file_list
Data Types for lc_shell
file_list list
ARGUMENTS
file_list
Specifies a list of files to read. When specifying more than
one input_file, enclose the list of names in braces ({}).
-define macro_names
Specifies a list of top-level macros for verilog and systemver-
ilog only.
So it should be "-define macro_names"
