Aiden Attenborough
Newbie level 1
Hi, I'm currently working on a very simple project for my pc, which is basically just a TiP31 Transistor connected to an audio jack and a strip of LED's which is powered by a molex connecter coming from my PC's power supply.
I currently have a cold cathode setup with a "sound module" that I bought separately at the time which doesn't work with an audio jack, but with a small microphone inside its case. It also has a variable resistor which is used to change the sensitivity of the microphone.
Is it possible to have a similar setup with the transistor? Is there any way at all to control the sensitivity? With a Trimpot possibly?
Thanks!
Thanks!
