skatefast08
Full Member level 4
How should I pick the correct type of potentiometer that will measure an angle to the nearest arcsecond (.000278 degrees)? What parameters and their values for a potentiometer would be important to consider for this kind of application?
I believe if I used a random potentiometer, it may not have the same resistance value at the same position (.000278 degrees difference) from the position it was before. Maybe I need to consider noise? Or some kind of tolerance. Maybe even a larger potentiometer that works up to 100 kOhm would have more resistance values and therefore reduce the angle error. What would do?
