User Testbench for Core1553BRT_APB in LiberoSoc
Altair99
Newbie
Newbie level 3
Hello everyone!
In LiberoSoc IDE I'm trying to simulate a remote terminal of the MIL-STD-1553B interface using the IP core Core1553BRT_APB. For this i'm using the User Testbench provided by this core. When I launch RTL simulation (I'm using ModelSim Microsemi Pro 2020.4), it gives me
Error (suppressible): (vsim-3584) Module parameter 'ARGVALUE0' not found for override.
Here is the full log:
Reading pref.tcl
# do run.do
# Model Technology ModelSim Microsemi Pro vmap 2020.4 Lib Mapping Utility 2020.10 Oct 14 2020
# vmap PolarFire C:/Microsemi/Libero_SoC_v2021.2/Designer/lib/modelsimpro/precompiled/vlog/PolarFire
# Modifying modelsim.ini
# vmap CORE1553BRT_APB_LIB ../component/Actel/DirectCore/CORE1553BRT_APB/4.4.100/mti/lib_vlog_eval/CORE1553BRT_APB_LIB
# Model Technology ModelSim Microsemi Pro vcom 2020.4 Compiler 2020.10 Oct 14 2020
# Start time: 22:17:18 on Sep 12,2024
# vcom -reportprogress 300 -work CORE1553BRT_APB_LIB -force_refresh
# -- Skipping module BFM_1553BBC
# -- Skipping module BFM_APB
# -- Skipping module BFM_MAIN
# -- Skipping module BFMA1l1OII
# -- Skipping module BRT_BACKEND
# -- Skipping module BRT_CWLEGALITY
# -- Skipping module BRT_DECODER
# -- Skipping module BRT_ENCODER
# -- Skipping module BRT_RT1553B
# -- Skipping module CORE1553BRT_APB_C0_CORE1553BRT_APB_C0_0_CORE1553BRT_APB
# -- Skipping module QTRANSCEIVER
# -- Skipping module TB_AMBA
# End time: 22:17:18 on Sep 12,2024, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# Model Technology ModelSim Microsemi Pro vlog 2020.4 Compiler 2020.10 Oct 14 2020
# vlog -reportprogress 300 -work CORE1553BRT_APB_LIB -force_refresh
# -- Refreshing module BFM_1553BBC
# -- Refreshing module BFM_APB
# -- Refreshing module BFM_MAIN
# -- Refreshing module BFMA1l1OII
# -- Refreshing module BRT_BACKEND
# -- Refreshing module BRT_CWLEGALITY
# -- Refreshing module BRT_DECODER
# -- Refreshing module BRT_ENCODER
# -- Refreshing module BRT_RT1553B
# -- Refreshing module CORE1553BRT_APB_C0_CORE1553BRT_APB_C0_0_CORE1553BRT_APB
# -- Refreshing module QTRANSCEIVER
# -- Refreshing module TB_AMBA
# vlog -reportprogress 300 -sv -work CORE1553BRT_APB_LIB D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/amba_eval/core1553brt_apb.v
# -- Compiling module CORE1553BRT_APB_C0_CORE1553BRT_APB_C0_0_CORE1553BRT_APB
# Top level modules:
#   CORE1553BRT_APB_C0_CORE1553BRT_APB_C0_0_CORE1553BRT_APB
# vlog -reportprogress 300 "+incdir+D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/Actel/DirectCore/CORE1553BRT_APB/4.4.100/rtl/verilog/tb_amba_eval" "+incdir+D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval" -sv -work CORE1553BRT_APB_LIB D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/Actel/DirectCore/CORE1553BRT_APB/4.4.100/rtl/verilog/tb_amba_eval/qtransceiver.v
# -- Compiling module QTRANSCEIVER
#   QTRANSCEIVER
# vlog -reportprogress 300 "+incdir+D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0" "+incdir+D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/Actel/DirectCore/CORE1553BRT_APB/4.4.100/rtl/verilog/tb_amba_eval" "+incdir+D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval" -sv -work CORE1553BRT_APB_LIB D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v
# -- Compiling module TB_AMBA
#   TB_AMBA
# vsim -L PolarFire -L CORE1553BRT_APB_LIB -t 1ps -pli "C:/Microsemi/Libero_SoC_v2021.2/Designer/lib/modelsimpro/pli/pf_crypto_win_me_pli.dll" CORE1553BRT_APB_LIB.TB_AMBA
# //  ModelSim Microsemi Pro 2020.4 Oct 14 2020
# //  Copyright 1991-2020 Mentor Graphics Corporation
# //  All Rights Reserved.
# //  ModelSim Microsemi Pro and its associated documentation contain trade
# //  secrets and commercial or financial information that are the property of
# //  Mentor Graphics Corporation and are privileged, confidential,
# //  and exempt from disclosure under the Freedom of Information Act,
# //  5 U.S.C. Section 552. Furthermore, this information
# //  is prohibited from disclosure under the Trade Secrets Act,
# //  18 U.S.C. Section 1905.
# Loading sv_std.std
# Loading CORE1553BRT_APB_LIB.TB_AMBA
# Loading CORE1553BRT_APB_LIB.BFM_1553BBC
# Loading CORE1553BRT_APB_LIB.BRT_ENCODER
# Loading CORE1553BRT_APB_LIB.BRT_DECODER
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE0' not found for override.
#    Time: 0 ps  Iteration: 0  Instance: /TB_AMBA File: D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE1' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE10' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE11' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE2' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE3' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE4' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE5' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE6' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE7' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE8' not found for override.
# ** Error (suppressible): (vsim-3584) D:/Work_Projects/LiberoSoc/UserTestbench_1553BRT/component/work/CORE1553BRT_APB_C0/CORE1553BRT_APB_C0_0/rtl/verilog/tb_amba_eval/tb_amba.v(342): Module parameter 'ARGVALUE9' not found for override.
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./run.do PAUSED at line 14
Below is the code where these parameters are mentioned only once - this is a fragment of the testbench where an instance of the BFM_APB module is called:
BFM_APB #( .VECTFILE        ( "core1553brt.vec"),
               .MAX_INSTRUCTIONS( 8192),
               .MAX_STACK       ( 200),
               .TPD             ( 5),
               .DEBUGLEVEL      ( -1),
               .ARGVALUE0       ( VERIF),
               .ARGVALUE1       ( NRTS),
               .ARGVALUE2       ( FAMILY),
               .ARGVALUE3       ( SU_CLKSPD),
               .ARGVALUE4       ( SU_CLKSYNC),
               .ARGVALUE5       ( SU_LOCKRT),
               .ARGVALUE6       ( BCASTEN),
               .ARGVALUE7       ( SU_LEGMODE),
               .ARGVALUE8       ( SA30LOOP),
               .ARGVALUE9       ( INTENBBR),
               .ARGVALUE10      ( SU_TESTTXTOUTEN),
               .ARGVALUE11      ( SU_INT_POLARITY)
    ) BFM(
        .SYSCLK(SYSCLK),
        .SYSRSTN(SYSRSTN),
        .PCLK(PCLK),
        .PRESETN(PRESETN),
        .PADDR(PADDR),
        .PENABLE(PENABLE),
        .PWRITE(PWRITE),
        .PWDATA(PWDATA),
        .PRDATA(PRDATA),
        .PREADY(PREADY),
        .PSLVERR(PSLVERR),
        .PSEL(PSEL),
        .INTERRUPT(INTERRUPT),
        .GP_OUT(GP_OUT),
        .GP_IN(GP_IN),
        .EXT_WR(EXT_WR),
        .EXT_RD(EXT_RD),
        .EXT_ADDR(EXT_ADDR),
        .EXT_DATA(EXT_DATA),
        .EXT_WAIT(EXT_WAIT),
        .FINISHED(FINISHED),
        .FAILED(FAILED)
As can be seen, ARGVALUE0 - ARGVALUE11 are the parameters of the BFM_APB module, which implements the APB Bus Functional Model. According to the Core1553BRT_APB 4.3 Handbook documentation (p.30), this module generates bus cycles using the core1553brt.bfm command file.Due to the restricted license, the BFM_APB module in my project is provided as a pre-compiled simulation model and is not available for viewing or editing.
I've looked through a lot of documentation (Core1553BRT_APB 4.3 Handbook, Core1553BRT_APB 4.2 Handbook, DirectCore AMBA BFM User's Guide, Libero SoC Design Flow User Guide, SmartDesign User Guide, etc.) and various forums, but I haven't found answers to my questions - what causes this error? And what should I do to fix it?
Maybe I'm very inattentive and inexperienced and missing something obvious, so I'm asking for help.
In any case, I'd appreciate any help. Thanks in advance!
Solution
Finally, I managed to run this testbench. Initially, I tried to run it on PolarFire family in LiberoSoc v.2021.2:
And I didn't succeed because of the error described in my question.
Then, I tried to run it on other families and I succeeded on IGLOO2 and SmartFusion2. Below is a screenshot of waveforms obtained as a result of running the testbench:
In my opinion you need to take up this matter with the source that provided you the pre-compiled simulation model. Because it is not possible for you to change or for us to view and provide suggestions due to the pre-compiled nature.
Without fully understanding these it is difficult for me to comment.
.ARGVALUE1       ( NRTS),
.ARGVALUE1       ( NRTS),
Thank you for your reply, dpaul!
The source of this pre-compiled simulation model is the Libero Soc IDE. Of course, my first idea was to ask this question on their forum. And the only reason I haven't done it yet is that when I try to register, this site denies me access. I've tried this on different computers, phones, Internet providers and several VPN services. The result is the same - Access Denied. So, I will think about how to work around this issue.
Anyway, thank you for advice!
Solution
LaTeX Commands Quick-Menu:
