use xilinx component with vhdl
mc&fpga
Member level 1
Member level 1
xilinx using components in vhdl
to use xilinx component like dll and ibuf or obuf (the component use in schematic )in vhdl code for using this componet which library should select?
xilinx component
You can look in Language templates Idem... look in the High right border of Xilinx Foundation Windows.... There's a light ...
In Language Templates there's All components....
[/img]
if you use ise if you create a new source there is two lines tha you mest decomment and you can abil the xilinx library.
bye
library unisim;
use unisim.vcomponents.all;
ya, as others have suggested, by adding these two lines u'll be able to use most of xilinx components like clkdlls, ibufgs etc..
tut..
when you use xilinx library please read carefully the library book, some devices differ if you use it for implement and to simulate.
bye.
G.
