Use "Vector VN1610" and a serial terminal instead of "Vector CANoe"
ArakelTheDragon
Member level 3
Member level 3
If you like the post, please press "Like".
Hi guys,
I hope this is the correct place for my topic, if not please move it.
I am trying to get a serial terminal to work with "Vector VN1610" because I prefer to use it instead of "Vector CANoe", on "CANoe" everything works, but when I use the terminal I get "connected to device", however I receive no response or some random numbers which mean nothing to me. I use the following format:
REQUEST: CAN ID, DLC, Request(720 2 10 01)
Connection to the COM port is done at 9600kbps(active connection).
I think the problem may be in the "Vector hardware" which is responsible for assigning "Vector CANoe" to 1 of the 2 "CAN channels", but it does not show my software, I don't know why.
