gezzas525
Full Member level 3
tools.lnx86 spp
Hi, iam trying to get the hspice models to work under spectre, specificaly the tsmc18 models. Taking the hspice/public/publicmodels of the tsmc I converted it to spectre format using spp:
spp -convert < tsmc18dN > tsmc18N
etc..
when I come to simulate it I get the following errors
Error found by spectre during circuit read-in.
"/home/kleo/cadence/mymodels/N" 1: Illegal library definition found in
netlist
"/home/kleo/cadence/mymodels/P" 2: Illegal library definition found in
netlist
"/home/kleo/cadence/mymodels/P" 4: Duplicate name `section'.
spectre terminated prematurely due to fatal error.
so after this I delete the library section and xmos sections and then it simulates but gives a few warnings:
Command line:
spectre -env artist5.0.0 +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre8_4082_18 -format psfbin -raw ../psf \
input.scs
spectre pid = 7204
Loading /home/kleo/cadence/tools.lnx86/spectre/lib/cmi/2.0/libinfineon_sh.so
Loading /home/kleo/cadence/tools.lnx86/spectre/lib/cmi/2.0/libnortel_sh.so ...
Loading /home/kleo/cadence/tools.lnx86/spectre/lib/cmi/2.0/libphilips_sh.so
Loading /home/kleo/cadence/tools.lnx86/spectre/lib/cmi/2.0/libstmodels_sh.so
spectre (ver. 5.0.0.120902 -- 09 Dec 2002).
Simulating `input.scs' on localhost.localdomain at 7:37:35 PM, Sun Jun 27,
2004.
Circuit inventory:
nodes 3
equations 5
bsim3v3 2
vsource 2
Entering remote command mode using MPSC service (spectre, ipi, v0.0,
spectre8_4082_18, ).
Transient Analysis `tran': time = (0 s -> 10 ns)
Warning from spectre during IC analysis, during transient analysis `tran'.
P0: Vgs has exceeded the oxide breakdown voltage of `vbox' = 4 V.
P0: Vgd has exceeded the oxide breakdown voltage of `vbox' = 4 V.
N0: Vgd has exceeded the oxide breakdown voltage of `vbox' = 4 V.
Important parameter values:
start = 0 s
outputstart = 0 s
stop = 10 ns
step = 10 ps
maxstep = 200 ps
ic = all
skipdc = no
reltol = 1e-03
abstol(V) = 1 uV
abstol(I) = 1 pA
temp = 27 C
tnom = 27 C
tempeffects = all
errpreset = moderate
method = traponly
lteratio = 3.5
relref = sigglobal
cmin = 0 F
gmin = 1 pS
Warning from spectre at time = 10 ps during transient analysis `tran'.
Notice from spectre at time = 204.192 ps during transient analysis `tran'.
P0: Device leaves the gate-source oxide breakdown region.
P0: Device leaves the gate-drain oxide breakdown region.
N0: Device leaves the gate-drain oxide breakdown region.
tran: time = 270.1 ps (2.7 %), step = 65.86 ps (659 m%)
tran: time = 773.1 ps (7.73 %), step = 73.75 ps (738 m%)
Warning from spectre at time = 878.256 ps during transient analysis `tran'.
Further occurrences of this warning will be suppressed.
N0: Vgs has exceeded the oxide breakdown voltage of `vbox' = 4 V.
tran: time = 1.346 ns (13.5 %), step = 157.5 ps (1.58 %)
tran: time = 1.946 ns (19.5 %), step = 200 ps (2 %)
tran: time = 2.346 ns (23.5 %), step = 200 ps (2 %)
tran: time = 2.946 ns (29.5 %), step = 200 ps (2 %)
tran: time = 3.346 ns (33.5 %), step = 200 ps (2 %)
tran: time = 3.946 ns (39.5 %), step = 200 ps (2 %)
tran: time = 4.346 ns (43.5 %), step = 200 ps (2 %)
tran: time = 4.873 ns (48.7 %), step = 126.9 ps (1.27 %)
Notice from spectre at time = 5.21116 ns during transient analysis `tran'.
N0: Device leaves the gate-source oxide breakdown region.
tran: time = 5.348 ns (53.5 %), step = 137.2 ps (1.37 %)
tran: time = 5.796 ns (58 %), step = 64.96 ps (650 m%)
Warning from spectre at time = 5.87779 ns during transient analysis `tran'.
tran: time = 6.437 ns (64.4 %), step = 195.6 ps (1.96 %)
tran: time = 6.837 ns (68.4 %), step = 200 ps (2 %)
tran: time = 7.437 ns (74.4 %), step = 200 ps (2 %)
tran: time = 7.837 ns (78.4 %), step = 200 ps (2 %)
tran: time = 8.437 ns (84.4 %), step = 200 ps (2 %)
tran: time = 8.837 ns (88.4 %), step = 200 ps (2 %)
tran: time = 9.437 ns (94.4 %), step = 200 ps (2 %)
tran: time = 9.837 ns (98.4 %), step = 200 ps (2 %)
Number of accepted tran steps = 103.
Initial condition solution time = 0 s.
Intrinsic tran analysis time = 10 ms.
Total time required for tran analysis `tran' was 10 ms.
Warning from spectre.
3 warnings suppressed.
finalTimeOP: writing operating point information to rawfile.
modelParameter: writing model parameter values to rawfile.
element: writing instance parameter values to rawfile.
outputParameter: writing output parameter values to rawfile.
designParamVals: writing netlist parameters to rawfile.
What is the model file suppost to look like for the spectre simulator?
etc..
netlist
netlist
Command line:
input.scs
spectre pid = 7204
2004.
Circuit inventory:
nodes 3
equations 5
bsim3v3 2
vsource 2
start = 0 s
outputstart = 0 s
stop = 10 ns
step = 10 ps
maxstep = 200 ps
ic = all
skipdc = no
reltol = 1e-03
abstol(V) = 1 uV
abstol(I) = 1 pA
temp = 27 C
tnom = 27 C
tempeffects = all
method = traponly
lteratio = 3.5
relref = sigglobal
cmin = 0 F
gmin = 1 pS
