Use the ESP8266 WiFi module (such as ESP-12E) to achieve a stable connection of technical issues
gavinray
Member level 1
Member level 1
Hello everyone
I plan to use ESP8266 WiFi module for a stable connection project. Before starting, I want to sort out some technical issues about this WiFi module to ensure that I can configure and use it correctly to obtain stable connection performance. Here are some of my concerns:
Module Compatibility: How can I confirm that the ESP-12E WiFi module is compatible with my planned application? Are there any specifications or features that require special attention?
Connection Stability: Achieving a stable connection is my number one goal. Are there any known connection drop issues? How to set up to ensure the stability of the connection?
Power Management: Does using the ESP-12E module have a noticeable impact on power consumption? Are there power saving strategies to consider to extend battery life?
Signal Strength and Antennas: How to evaluate the signal strength of the ESP-12E module, and how to optimize the antenna settings to achieve the best signal quality?
Channel Selection and Interference: How to choose the best WiFi channel on the ESP-12E to avoid interference? Is there a trick to reduce the impact of interference?
Data transfer and protocol: Should I use a specific data transfer protocol (such as 802.11n) for connection stability? How to ensure the reliability of data transmission?
I have had ESP8266 and ESP32 working continuously for about 18 months with no stability issues, they are very reliable.
This is a generic problem with all MCU devices. If it has enough I/O pins and memory it should work. How many pins needed and size of your program is unknown to us.
I have never had problems except for mobile applications going out of range occasionally. That would happen with any WiFi device. There are ways to detect loss of connection and attempt to reconnect in most program libraries. At data level, I would suggest you use some kind of protected protocol if possible, I use MQTT in most cases because it has built-in methods to ensure secure data transfers.
Power consumption is almost entirely by the WiFi transmitter and can peak at around 250mA. If you want to extend battery life and your application doesn't need continuous transmission there are methods to put the device to sleep until woken up externally or by an internal timer. When asleep, consumption is only a few uA.
Most have built-in omni-directional antennas. In open space they typically have a range of 100m (100yds). Some have external antenna connections which if suitably connected to a directional antenna should give a range of around 1Km (0.6 mile).
In most circumstances you would be connecting to another ESP device, as long as they are told to use the same channel there wont be a problem. If you are connecting to a WiFi router in most cases the router will decide which channel to use. The only way to know which channel is 'cleanest' is to monitor them all but beware that if other WiFi devices are nearby, they may also swap channels, don't assume things are always the same, especially if mobile phones using WiFi are nearby. The transmission protocol allows for several devices to share a single channel without interfering with each other so it isn't usually a problem.
The data transfer protocol is probably fixed by the manufacturer or by ready built libraries you use. Integrity of data and re-transmission in case or errors is normally dealt with automatically, even if there are short breaks in signal link. It is up to you how to deal with longer breaks if data 'backs up' waiting to be sent but most transfer protocols have methods to handle that problem if it arises.
Brian.
