Use SR Latch's or just hook up some NANAD gates?
T
treez
Newbie level 1
Hello,
I need one NAND latch in my circuit.
Would i be better off using one of the latchs on the SN74279 chip?
SN 74279
https://www.ti.com/lit/ds/sdls093/sdls093.pdf
..............or is it better to use a quad NAND chip and connect two of the NAND gates as a NAND latch?
...eg 74LVC00A.....
74LVC00A
Hi treez,
Using the latch chip will make your circuit simpler. But if you want to make a detail study of the latch while designing your circuit, you can try the quad nand gate chip.
Reactions: treez
    T
