Manivannan M
Junior Member level 1
In serial circuit current is same for all resistor,then what is the operations of resistor?
resistor is used for the purpose of current limitation. as the value of resistance increases current flow decreses
Yes, that's right.But in series circuit current is same for all resistor.
No. Maybe you are thinking of parallel circuit?if resistor of equal resistance is used in series then only current flow in every resistance will be the same. other wise it will not be the same.
study kirchoffs current law
https://en.wikipedia.org/wiki/Kirchoff's_circuit_laws
In series circuit it is completely wrong .resistor is used for the purpose of current limitation. as the value of resistance increases current flow decreses
