cupoftea
Advanced Member level 6
We have a USB Type 2.0 connection coming on to a board, where it connects to a PIC micro. The connector is TE Connectivity 2173157.
Do you believe that all USB2.0 cables on the market, that connect with the above connector, will be shielded cables?
2173157 USB 2.0 connector
Also, would you agree that all USB2.0 connections coming on to a board from a cable, will need a common mode choke to be fitted at the cable entrance point, on the PCB? (in the D+ AND D- lines)
...___...___
Also, the USB2.0 has five connections, D+, D-, VBUS,ID and 0V.
We use a common mode choke for D+ AND D-.
And for VBUS, ID and 0V, would you agree that these need a ferrite bead to be placed in their tracks, right by the connector?
....___...___..---...---
This connector......
...is for USB 2.0. It has a metal shell, which is supposed to be connected to circuit 0V. But do you think its best to connect it to circuit 0V via a ferrite bead? (ie, for the purposes of radiated emissions suppression , for passing EN55032 EMC testing)
...---...___...---...___
...___...___
--- Updated ---
