USB to parallel converter
sheraz.pervaiz
Member level 4
Member level 4
Do u know some device which can convert serial data from USB port to parallel ??
FTDI has chip for that FT245BM and FT245BL i think. There is also dongles to buy that does USB to parallel.
https://www.ftdichip.com/
But USB to parallel adapters and chips are a bit hard to get to work, not the same as serial adapters. Lots of programs using parallel port does it with direct hardware access and then its realy hard for the USB driver needed.
regards Med
