USB storage is not able to connect...
fork03
Newbie level 3
Newbie level 3
I am new to this forum... pls help me..
I am using nios2 processor on my embedded device which has ISP1761 host controller in it ...I have 3 usb ports.
Problem is, when i am inserting usb storage device to one of my port then following kind of error messages are coming ..I am attaching some o/ps to understand the things...
o/p of cat /proc/bus/usb/devices
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=01 Dev#= 10 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0ea0 ProdID=6828 Rev= 1.10
S: Manufacturer=USB
S: Product=Flash Disk
S: SerialNumber=181707D840A65E66
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
o/p of DMESG
usb 1-1: new high speed USB device using isp1761-hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 3 ports detected
sb 1-1.3: new full speed USB device using isp1761-hcd and address 4
usb 1-1.3: configuration #1 chosen from 1 choice
usb-storage: USB Mass Storage device detected
usb-storage: -- associate_dev
usb-storage: Vendor: 0x0ea0, Product: 0x6828, Revision: 0x0110
usb-storage: Interface Subclass: 0x06, Protocol: 0x50
usb-storage: Transport: Bulk
usb-storage: Protocol: Transparent SCSI
scsi1 : SCSI emulation for USB Mass Storage devices
usb-storage: *** thread sleeping.
usb-storage: device found at 4
usb-storage: waiting for device to settle before scanning
usb-storage: usb_stor_control_msg: rq=fe rqtype=a1 value=0000 index=00 len=1
usb-storage: GetMaxLUN command result is 1, data is 0
usb-storage: queuecommand called
usb-storage: *** thread awakened.
usb-storage: Command INQUIRY (6 bytes)
usb-storage: 12 00 00 00 24 00
usb-storage: Bulk Command S 0x43425355 T 0x1 L 36 F 128 Trg 0 LUN 0 CL 6
usb-storage: usb_stor_bulk_transfer_buf: xfer 31 bytes
usb-storage: Status code 0; transferred 31/31
usb-storage: -- transfer complete
usb-storage: Bulk command transfer result=0
usb-storage: usb_stor_bulk_transfer_sglist: xfer 36 bytes, 1 entries
usb-storage: Status code 0; transferred 36/36
usb-storage: Bulk data transfer result 0x0
usb-storage: Attempting to get CSW...
usb-storage: usb_stor_bulk_transfer_buf: xfer 13 bytes
usb-storage: Status code -32; transferred 0/13
usb-storage: clearing endpoint halt for pipe 0xc0008480
usb-storage: usb_stor_control_msg: rq=01 rqtype=02 value=0000 index=81 len=0
usb-storage: usb_stor_clear_halt: result = 0
usb-storage: Attempting to get CSW (2nd try)...
usb-storage: Bulk status result = 2
usb-storage: -- transport indicates error, resetting
usb-storage: storage_pre_reset
usb 1-1.3: reset full speed USB device using isp1761-hcd and address 4
usb 1-1.3: device not accepting address 4, error -22
usb 1-1.3: device descriptor read/64, error -19
usb-storage: storage_post_reset
usb-storage: usb_reset_composite_device returns -19
usb-storage: usb_stor_Bulk_reset called
usb-storage: usb_stor_control_msg: rq=ff rqtype=21 value=0000 index=00 len=0
usb-storage: Soft reset failed: -19
usb-storage: scsi cmd done, result=0x70000
usb-storage: Bulk Command S 0x43425355 T 0x2 L 36 F 128 Trg 0 LUN 0 CL 6
usb-storage: Status code -19; transferred 0/31
usb-storage: -- unknown error
usb-storage: Bulk command transfer result=4
usb-storage: unable to lock device for reset: -19
usb-storage: Bulk Command S 0x43425355 T 0x3 L 36 F 128 Trg 0 LUN 0 CL 6
usb-storage: Bulk Command S 0x43425355 T 0x4 L 36 F 128 Trg 0 LUN 0 CL 6
usb-storage: Bad target number (1:0)
usb-storage: scsi cmd done, result=0x40000
usb-storage: Bad target number (2:0)
usb-storage: Bad target number (3:0)
usb 1-1.3: USB disconnect, address 4
usb-storage: storage_disconnect() called
usb-storage: usb_stor_stop_transport called
usb-storage: Fail command during disconnect
usb-storage: device scan complete
usb-storage: -- usb_stor_release_resources
usb-storage: -- sending exit command to thread
usb-storage: -- dissociate_dev
usb-storage: -- exiting
usb 1-1.3: new full speed USB device using isp1761-hcd and address 5
scsi2 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 5
usb-storage: clearing endpoint halt for pipe 0xc0008580
usb-storage: Timeout -- cancelling URB
usb-storage: usb_stor_clear_halt: result = -2
usb-storage: Bulk status result = 4
usb 1-1.3: reset full speed USB device using isp1761-hcd and address 5
usb-storage: command_abort called
/> usb 1-1.3: device not accepting address 5, error -110
scsi 2:0:0:0: scsi: Device offlined - not ready after error recovery
usb 1-1.3: USB disconnect, address 5
uname -r
2.6.19-uc1
I am using uClinux as my operating system. And same embedded device is working with usb storage kingston 2.0 but not working with upper one. Even upper one is working with my fedora system.
Pls help me ....
