USB slot voltage and Current drive specification??
buts101
Full Member level 3
Full Member level 3
usb voltage specification
Can usb can drive 2 channel speakers? What are the voltage and current drive specification. I see, mp3 player are charged through usb drive.
Best regards,
Buts101
usb drive voltage
Hi
According to the specs a USB device can't sink more than 500mA @5V if it's connected on the main hub or self powered hub.
and if the device is connected to a buspowred hub it can sink up to 100mA@5V.
If you neeed more power you must make your USB Device self powred and not Bus powred
you can check the usb specs @
www.usb.org
or for simplicity you can check
http://www.beyondlogic.org/usbnutshell/usb1.htm
and this link may help you too
Salam
Hossam Alzomor
www.i-g.org
