Rajinder1268
Full Member level 3
Hi all,
I am tracking a board which has USB 2.0 requirement.
The USB to UART has the D+ and D- pins switched. This means that I am having to use vias in between the Micro USB connector and D+/- lines.
I have a 4 layer PCB, tracking on top, GND is 2nd, power is 3rd and 4th layer is for signals.
Are using vias going to be an issue. The track length difference between the diff pair is 2mm. It is impedance controlled at 90ohm.
I read that if the track length is less than 1/10th of wavelength of max frequency . The length of the tracking does not matter.
For usb high speed this equates to 20.5mm and low speed it is 165mm.
