USB Power supply Pin detail.
W
Wolfram
I want to make a USB charger for Tablet, mp3 player. My design is simple using 7805 for 5V. What to do with D+ and D- pins ?
Hello,
These pins are used for data transfers. If u use it only to charge your device, leave without connections.
Hope this helps.:wink:
    V
The data pins are used to identify charging capabilities. If left open, some devices may not charge (they will not recognize the charger as a valid device) or they may charge very slowly.
You can download the specs here:https://www.usb.org/developers/docs/ or do a search for USB charging configurations.
I agree as what bking said, if u have any problems with this,
u need to search for a way out for it. (If in doubt, feel free to come back here and ask us so we can guide you:wink
I don't think that you can do anything for charging capabilities anouncement without dedicated hardware. In so far, unconnecting D+ and D- is probably the right suggestion.
Reactions: FvM
    FvM
If you want to sell your charger in high quantity, then please try to comply with usb standards.
Klaus
