USB only receive data.
jccsantos
Junior Member level 2
mpusbapi.dll
hello , i have a aplication that only needs the data in, how can i modify this code to read only data-in (continued) and remove the timer??????
the program will make only a job off a logger with data incoming.
The schematic is based in PIC18F2550 with USB and uses mpusbapi.dll.
The pic will send data (1 byte) every second, and do not receive any.
This is the code:
unit main;
interface
uses
  Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs,
  StdCtrls, ComCtrls, ExtCtrls, Menus, A3nalogGauge, Buttons, rxtimerlst;
type
  TForm1 = class(TForm)
    StatusBar1: TStatusBar;
    Button1: TButton;
    Edit1: TEdit;
    Label2: TLabel;
    Timer1: TTimer;
    BtnTemp: TSpeedButton;
    EditMin: TLabeledEdit;
    EditMax: TLabeledEdit;
    procedure FormClose(Sender: TObject; var Action: TCloseAction);
    procedure Label2Click(Sender: TObject);
    procedure Button1Click(Sender: TObject);
    procedure FormCreate(Sender: TObject);
    procedure BtnTempClick(Sender: TObject);
    procedure Timer1Timer(Sender: TObject);
  private
    { Private declarations }
  public
  end;
   Const
   MAXSIZE=64;
   MPUSB_FAIL=0;
   MPUSB_SUCCESS=1;
   MP_WRITE:DWORD=0;
   MP_READ:DWORD=1;
   MAX_NUM_MPUSB_DEV=127;
  type
  DWORD = LongInt;
  PCHAR8 =  array[0..MAXSIZE] of char;
  PBYTE = array[0..MAXSIZE] of BYTE;
  PDWORD =  array[0..MAXSIZE] of DWORD;
  PVOID = Pointer;
  UINT = Cardinal;
function _MPUSBGetDLLVersion():DWORD; stdcall;external 'mpusbapi.dll';
function _MPUSBGetDeviceCount(pVID_PID:PCHAR8):DWORD; stdcall;external 'mpusbapi.dll';
function _MPUSBOpen(instance:DWORD;pVID_PID:PCHAR8;pEP:PCHAR8;dwDir:DWORD;dwReserved:DWORD):THANDLE; stdcall;external 'mpusbapi.dll';
function _MPUSBRead(handle:THANDLE;var pData:PBYTE;dwLen:DWORD;var pLength:DWORD;dwMilliseconds:DWORD):DWORD; stdcall;external 'mpusbapi.dll';
function _MPUSBReadInt(handle:THANDLE;var pData:PBYTE;dwLen:DWORD;var pLength:PDWORD;dwMilliseconds:DWORD):DWORD; stdcall;external 'mpusbapi.dll';
function _MPUSBWrite(handle:THANDLE;pData:PBYTE;dwLen:DWORD;var pLength:DWORD;dwMilliseconds:DWORD):DWORD; stdcall;external 'mpusbapi.dll';
function _MPUSBClose(handle:THANDLE):DWORD; stdcall;external 'mpusbapi.dll';
var
  Form1: TForm1;
  vid_pid:PCHAR8='vid_04d8&pid_00c8';
  out_pipe:PCHAR8='\MCHP_EP1';
  in_pipe:PCHAR8='\MCHP_EP1';
  myOutPipe:THANDLE;
  myInPipe:THANDLE;
  isConnected:boolean;
implementation
uses ShellAPI;
{$R *.DFM}
procedure CheckInvalidHandle();
begin
  if(GetLastError=ERROR_INVALID_HANDLE) then
  begin
        _MPUSBClose(myOutPipe);
        _MPUSBClose(myInPipe);
        myInPipe:=INVALID_HANDLE_VALUE;
        myOutPipe:=INVALID_HANDLE_VALUE;
  end
  else
    ShowMessage('Error Code :'+inttostr(GetLastError()));
end;
function SendReceivePacket(SendData:PBYTE;SendLength:DWORD;var ReceiveData:PBYTE;
var ReceiveLength:DWORD;SendDelay:UINT;ReceiveDelay:UINT):DWORD; stdcall;
var
  SentDataLength:DWORD ;
  ExpectedReceiveLength:DWORD;
begin
 ExpectedReceiveLength:= ReceiveLength;
 if((myOutPipe <> INVALID_HANDLE_VALUE) and (myInPipe <> INVALID_HANDLE_VALUE)) then
   begin
    if(_MPUSBWrite(myOutPipe,SendData,SendLength,SentDataLength,SendDelay)<>0) then
     if(_MPUSBRead(myInPipe,ReceiveData,ExpectedReceiveLength,ReceiveLength,ReceiveDelay)<>0) then
       begin
       if(ReceiveLength = ExpectedReceiveLength) then
        begin
         Result:=1; // OK
         exit;
        end
       else
        if(ReceiveLength < ExpectedReceiveLength) then
         begin
           Result:=2; // failed, incorrect receive length
           exit;
         end
        end
     else
    else
   end
 else
   begin
     Result:=0; // Error
   end;
   end;
procedure TForm1.FormClose(Sender: TObject; var Action: TCloseAction);
begin
        if (myOutPipe <> INVALID_HANDLE_VALUE) then _MPUSBClose(myOutPipe);
        if (myInPipe <> INVALID_HANDLE_VALUE) then _MPUSBClose(myInPipe);
        myInPipe:= INVALID_HANDLE_VALUE;
end;
procedure TForm1.Label2Click(Sender: TObject);
var
  AnUrl: array[0..255] of char;
begin
  StrPCopy(AnUrl, 'http://XXXXXXXXXXXXX/');
  ShellExecute(Application.Handle, 'open', AnUrl, nil, nil, SW_NORMAL);
end;
//Ligar dispositivo usb
procedure TForm1.Button1Click(Sender: TObject);
var
   selection:DWORD;
   send_buf:PBYTE;
   receive_buf:PBYTE;
   RecvLength:DWORD;
begin
  selection:=0; // USB device that have PID & VID as we configed.
  if (_MPUSBGetDeviceCount(vid_pid)=0) then
  begin
    StatusBar1.Panels[1].text:='Estado : dispositivo não encontrado';
    StatusBar1.Panels[0].text:='Versão Firmware : ????';
    exit;
  end
  else
  begin
    StatusBar1.Panels[1].text:='Estado : Dispositivo Ligado';
    StatusBar1.Panels[0].text:='Versão Firmware : 0.1';
  end;
  myOutPipe:= _MPUSBOpen(selection,vid_pid,out_pipe,MP_WRITE,0);
  myInPipe:= _MPUSBOpen(selection,vid_pid,out_pipe,MP_READ,0);
  if ((myOutPipe = INVALID_HANDLE_VALUE) or (myInPipe = INVALID_HANDLE_VALUE)) then
  begin
   StatusBar1.Panels[1].text:='Estado : USB Error';
   exit;
  end;
end;
procedure TForm1.FormCreate(Sender: TObject);
begin
        timer1.Enabled := false;
end;
 procedure TForm1.BtnTempClick(Sender: TObject);
begin
  timer1.Enabled :=  BtnTemp.Down  ;
  if BtnTemp.Down   then BtnTemp.Caption := 'Parar'
  else
  BtnTemp.Caption := 'Temporizar';
end;
procedure TForm1.Timer1Timer(Sender: TObject);
var
   selection:DWORD;
   send_buf:PBYTE;
   receive_buf:PBYTE;
   RecvLength:DWORD;
begin
  begin
   exit;
  end;
  send_buf[0]:= $00;    // command
  send_buf[1]:=1;               // Expected length of the result
  RecvLength:=1;
 if(SendReceivePacket(send_buf,1,receive_buf,RecvLength,1000,1000) = 1) then
  begin
   if receive_buf[1] =0 then
   begin
     edit1.Text := IntToStr(Receive_buf[0]) ;
     end;
  end
  else
  begin
     StatusBar1.Panels[1].Text:='Estado : Erro Comunicação!';
  end;
  end;
end.
Thanks in advance.
